Sanketh
Mar 28, 2018Aspirant
Wifi Speed Issues on Orbi AC3000
Hi All,
I recently bought Orbi AC3000 Tri Band for my house. I previously had google wifi but moved over to Orbi as friends suggested higher throughout. I have a 1gb comcast line- With ethernet cable, I get upto 950 MPBS (on Arris sb8200) but with Orbi, I only get 450 MBPS tops. Can someone guide here?
Are you testing with a ethernet connected PC with the Orbi. Don't use wireless. Wireless speeds on client side hw varies and some device don't support 900+- speeds. You'll need to check with the devices Mfr to see what actual thruput speeds they support. Most mobile devices don't support much over 400-500Mb.
What FW are you using on the Orbi?
- SankethAspirant
Hello- I am tested with Ethernet cable connect to Dell PC. Sorry- I am a rookie in terms of terminology- Can you please tell me what MFR stands for?
My Setup: Arris sb8200)>Orbi AC3000>Mac book pro or iOS.
Please let me know if there is a trouble shooting steps I can follow
Mfr=Manufacturer
Does the Mac have ethernet support? if it does, try testing with that. Most wifi on Mac or mobile devices won't see those higher speeds.
:smileywink:
- guzzijasonApprentice
The best you can realisticly hope to achieve over WiFI with the Orbi is in the ballpark of 500-600 Mbps, and that will vary depending on how "clean" your WiFi environment is. It also assumed there are no upstream bottlenecks.
- SankethAspirant
Is that because of Orbi Limitations or something to do with the Modem?
Also depends on client HW support as well.
Limitations of the client wifi HW.
For reference:
https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-dataThese are theoretical limits based on the Orbi radio configuration. Your actual speeds will be less than this, whis is perfectly normal.
Good Info. Thanks for posting.
