Jefffe's avatar
Jefffe
Win10 stopped connecting to my routers DNS server
I have had all my Win10 devices, both LAN and wireless, stop receiving a valid IP from my RBR50
Orbi routers today, and now they have no internet. There was no Windows update, and I went through exhaustive network troubleshooting on my devices. My router firmware was just updated to Version V2.7.5.6, so I assume this is an issue with this firmware on this older Windows OS.
I confirmed this is only an issue with my Orbi router with this OS because I can connect these devices via LAN and wireless to other non-Netgear routers, and I have no issues with my non-Win10 devices. Is anyone else seeing this?
  • FURRYe38's avatar
    Any progress on this?
    Phixxit wrote:
    i had this happen to windows 11 pro computer.
    the way i resolved this was to assigne static IP addresses IP4, every thing started to work.
    this is some thing that started right after windows 11 update
    Pc is upgraded propley fron win 10 Pro
  • FURRYe38's avatar
    Is IPv6 enabled on the RBR?
    Using ISP detected DNS or custom DNS on the RBR?
    You cleared the DNS cache on the Win10 PC?
    Connect the Win10 PC directly to the ISP modem/ONT to see if it works there with out the RBR being online?
    Setting a manual DNS Static address on the Win10 PC change anything?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Brand and model# of the ethernet adapter in the Win10 PC?
    Ensure drivers are up to date aswell.
    • Phixxit's avatar
      Phixxit
      • FURRYe38's avatar
        So Win11 had been working then suddently exhibited this issue after an update? Might check into this update and see if it can be removed to see if it fixes this.
        There has been some known issues with recent Win11 updates. Something to check into.
        What is the brand and model# of the ethernet adapter and wireless adapters in these PCs?
    • Jefffe's avatar
      Jefffe
      Thank you for the insights. I have flushed IPv6 and tested the DNS settings on the operating system. I plan to power cycle the router once my wife finishes working from home. Fortunately, she uses a Mac and is experiencing no issues. I manually configured the IP address, which enabled me to start debugging the dynamic IP issue.
      • FURRYe38's avatar
        Seems to be a Win10 PC issue if your wifes Mac PC is working.
