GILLIAN
Jan 26, 2016Follower
Aircard 763S MEP Unlock tool
Help!
Trying to unlock the aircard (763S) but the link provided by Fido (service provider) is to a Sierra wireless website and does not work. I have installed the drivers, have an unlock code, but I haven't been prompted to enter it. Using a Mac - OS X El Capitan 10.11.13.
HELP ME!
Thanks.
Hello marilyn579
This article may help you.
https://kb.netgear.com/25909/MEP-Unlock-AirCard-753S
DarrenM
- ArodiDNETGEAR Expert
Hi Gillian,
If you have been supplied the unlock code, then all you need to do is insert another carrier SIM into your 763S. Once you boot it up, you will need to access the WebUI which will prompt you for the MEP code. All you need to do is enter the MEP code to unlock. Once it has been unlocked you will then need to go into the APN profile settings and ensure the correct APN profile has been selected as default/active connection. Please note: If you factory reset your 763S you will once again need to enter your unlock code.
Kind Regards,
Arodi
- chutieuswimmingAspirant
- Blanca_ONETGEAR Employee Retired
Hi chutieuswimming,
Here's a reference to resolve your concern: https://kb.netgear.com/22903/
Blanca
Community Team
- marilyn579Initiate
Help!! I have a aircard763s from Rogers. Trying to unlock it. I have a unlock code (pd $50.00 for it), but the instructions are useless. What is a WebUI?? Please help Grandma.
- DarrenMSr. NETGEAR Moderator
Hello marilyn579
DarrenM
Hello Gillian
Here is the link to the Aircard Watcher program to let you unlock your device.
http://kb.netgear.com/app/answers/detail/a_id/23681/related/1
http://www.downloads.netgear.com/files/aircard/AC340U/Watcher_Generic_UM.msi
DarrenM
