Squirt
Oct 14, 2015Aspirant
Aircard 785s won't turn on
4 months old aircard 785s will not turn on , will not charge or connect with PC via USB .
there is nothing wrong with the lead or the charger.
Currently trying to get phone support to return under warranty , by the time you lot get round to answering the phone it will have been cheaper for me to have just gone out and buy another!
Hello Squirt
I have sent you a Private message about your case.
DarrneM
- Lalu227AspirantHello I have a same problem in device 785s.could you please help me to resolve this issue.
- DarrenMSr. NETGEAR Moderator
Hello Lalu227
Have you tried to pull the battery and plug it in and power it on?
DarrenM
Hello Squirt
DarrneM
- dim-Aspirant
Hello, I have a similar problem. I can turn the device on, but the battery won't charge neither from the wall socket nor from the computer. How to solve this problem?
- SquirtAspirant
WIll yours turn on with the device plugged in to the mains, with the battery removed?
Sounds like you have a duff battery.
