Tmaciasm
Apr 23, 2023Initiate
APN 1028 error on MR6500
Please define and supply the fix on APN 1028 error
- JohnPengNETGEAR Expert
Tmaciasm wrote:
Please define and supply the fix on APN 1028 errorCould you please confirm whether you see the error code temporarily or it happens always and the data connection can never be set up?
Please capture a model.json file and send it to me by PM.
- Logon to the webui (http://192.168.1.1 ) as an administrator (Must log in as admin first)
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back - dalereifAspirant
07-03-2023
I am getting same error on a new MR6500 Pro. The request to confirm APN data is absurd on a new device. How am I as a consumer supposed to know that and it was working anyway. We are now rebooting the device every 30 minutes so I can work while away from home. Also, no where can I find what a 1028 error means. Short of going to a local AT&T store how do I fix this expensive "brick"? I posted information yesterday but now response. Firmware is current as of 06-17-23; environment is remote work from an RV. FYI; this device gets very warm (49 deg C) when working which seems unusual.
So what now?
Please capture a model.json file and send to my email jopeng@netgear.com.
dalereif wrote:
07-03-2023
So what now?
Did this get a solution? Mine is brand new and has done this twice in 14 hours.
The device locks up at this point and even though the APN is correct (broadband using AT&T) it will not reconnect without a reboot. I'm also wondering if everyone with this issue is using AT&T?
- X2T7EAspirant
On a Nighthawk M6 Pro purchased Thursday 13 July 23 from an AT&T storefront in Texas, cellular data service provided by AT&T, at a semi-remote location in Mississippi:
Nighttime hours, the cellular signal very often is too faint for the M6 to connect. Daytime hours, Friday the 14th, there were no apparent issues; Saturday the 15th, error 1208 and the associated message appears every 15-30 minutes. Additionally, while this reply was being prepared, it powered off. When I restarted it, there was a yellow warning triangle. Pressing the warning produced the message "battery charging stopped due to excessive heat" or something similar.
Is there a fix yet?
Is there a fix yet?
Thanks for providing the logs. I have replied with PM. Please check. If you have any question, you can email me directly at jopeng@netgear.com.
John
- edkroAspirant
I'm having the same issue with the APN on a Nighthawk M6 Pro purchased Wednesday 19 July 23 from an AT&T store in Mount Dora, FL, cellular data service provided by AT&T.
John I have emailed and Pm'd you my log file. Please let me know if you need any further information.
Ed
- Mela7AspirantShowing error with APN, why? This will also not allow me to connect.
Could you please email the model.json file to me at jopeng@netgear.com?
- Capture the results (by selecting all + copy) and send it backPlease also mention your community ID and detail your issues.
Thanks
Mela7 wrote:
Showing error with APN, why? This will also not allow me to connect.- M4rioAspirantSame problem in Germany
Provided by Telekom.
I have another router (Huawei) that works with the SIM card
- Joseph1221hoganAspirantI’m having the exact same problem with mines every 30 min I get the 1028 error can you please help me
