cmyorke1's avatar
cmyorke1
AT&T MR1100 Ethernet Port inop
I am using an AT&T branded Nighthawk MR1100. It recently updated firmware to 12.05.05.12. Since this update I am not able to connect to the ehternet port with any devices. I was using it with a Linksys Velop node and was working fine until the update. I was also able to connect my laptop to ethernet but am not able to currently.  The device was working correctly prior to the firmware update.
Can anyonne provide assistance.
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    We are actively working on this issue.
    Sorry for the inconvenience and thanks for your patience.
    Regards
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      Could you please advise when the issue happens on ethernet port, do you still can connect to WiFi and browse the internet?
      Thanks
      • cmyorke1's avatar
        cmyorke1
        Yes i am still able to connect to WIFI and browse. Once connected to ethernet there is no internet available through the port.
  • I just recently sold 2 Nighthawk AT&T LTE mobile hotspot routers in the ethernet is still not working is there a firmware update for this?
    • lukelu's avatar
      lukelu
      Got the same issue (We are using ATT bussiness plan). Wifi works but ethernet doesn't.
      • ar_james's avatar
        ar_james
        Same 'No Ethernet' issue on my MR1100 M1 router.  I have a trouble ticket open. I have the latest ATT provided firmware 12.05.05.14.   I saw some threads where this version should have corrected the issue.  My ethernet port is broken.  The wifi and the USB port will still connect.   I have a USB 3.0  to Ethernet adapter that came with my laptop plugged into the usb. That works for now, but I think there is a speed decrease from what ethernet would be.
