akernell
Nov 11, 2020Follower
Code 3
Hi everyone,
My MR1100 keeps shutting off on its own and now every time I try to turn it on, I get the error, "Code 3 Remove Battery and USB". Does anyone know how to fix this?
If you remove the battery and just have it powered from the usb, does it work?
- LrichardAspirant
Bonjour,
On the screen of the router I have the error message : 'code 3 remove battery and USB'
If I take off the battery and plug the USB cable only it works.
What's wrong and what should I do
Thanks
Richard
- LrichardAspirant
Bonjour Blanca,
Thank you for the answer.SKU is MR1100-1TLAUSfirmware version is NTG9X50C_12.06.08.00.Waiting from youBest regardsRichard - carolcooneyAspirantMine is doing this too. Did you figure out how to fix it?
- NickHarderAspirantHas anyone gotten a fix for this. Mine just started doing it randomly and now won’t go away.
- MikespeersAspirant
Hi, I have the same error code (3) when I installed a new battery. It works fine on usb. I see other people have had the same issue, can anyone help me please?
