Gidget21
Aug 22, 2022Tutor
Data usage info unavailable at this time Nighthawk M2 MR2100
Hi, I have had no data usage info showing on my Nighthawk M2 for the last couple of months.
I have spent a total of eight hours online to Telstra over the past few days with no resolution.
I'm pretty sure they have no idea what I am taking about, but I have done about 15 factory resets at their request to no avail. I have waited a further 72 hours and done another factory reset at their request, but nothing has changed and I don't have the patience or the time to waste trying to explain it to them once again! The last communication I had, they told me to "take it back to the Netgear shop and have them fix it" đ
This happened a couple of years ago with my previous device when Telstra "made some changes on their data usage server and broke the data usage display on M1. We are testing a fix for this issue and will have it addressed soon in the next couple of weeks."
Is there a similar problem again with the M2? Has Telstra changed the data usage server again and "broken" the data usage display on the M2 this time?
I just want my data usage display back đ
- Buckelew92110Aspirant
Hello,
There are no issues with data usage that Netgear are aware of.
Can you try rebooting the device to see if it comes back or do a factory reset on the unit.
Has there been any recent changes to your data plan?
Please also make sure the firmware is upto date by tapping Settings>Software>Check fo updates
- Gidget21Tutor
Hi, I have done all of those things several times and it has made no difference.
No recent changes to my plan that I am aware of.Thanks
- Gidget21Tutor
Is anyone able to help me? This is so frustrating!
- Blanca_ONETGEAR Employee Retired
Hi Gidget21,
Please provide the device SKU (e.g. MR2100-1TLAUS).
Kindly get in touch with Telstra and have them double check to ensure that device reached the billing server.Regards,
Blanca
Community Team
