rychro's avatar
rychro
Firmware Nighthakt M2
I have a bricked M2, it does not start. Please send me the current firmware.
Best regards
Roman
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi rychro,
    May we please know the device SKU (e.g. MR2100-1TLAUS)? This can be checked on the box of the product or on the barcode label
    Have you tried factory resetting the device? Please remove the SIM card and hold down the reset button until you see a change in the LED.
    Blanca
    Community Team
    • rychro's avatar
      rychro
      Dear Bianca
      The SKU is: MR2100-100EUS
      I've tried a factory reset several times. But this could not solve the problem.
      With no SIM installed.
      Best regards
      Roman
      • Blanca_O's avatar
        Blanca_O
        Hi rychro
        I have sent you a message. Please check your inbox.
        Blanca
        Community Team
      • Blanca_O's avatar
        Blanca_O
        Hi kopiko Transfluxor
        MR2100-1TLAUS is an ISP / Telstra SKU. There is no option to manually update the firmware as it is locked by the Internet Provider. All upgrades are provided over-the-air.
        Kindly describe the issue you are facing with your device. Can you please let us know what troubleshooting you've tried?
        Blanca
        Community Team
