Patatorz
Feb 20, 2026Star
MH7150 M7 not accepting my eSIM
Hello, just bought a M7 to use a eSIM from Free (working fine on my iPad Pro). Whatever with QR code or manual configuration, the installation of the eSIM is not working.
i would like to use it according to the big data associated to it in different countries.
as mentioned this is fine on my iPad.
Any clue how to make it work ?
The M7 is running the latest firmware.
thanks for your support
ludovic
- FortraLuminary
PLEASE CLICK ON THE LINK BELOW, FOR SOME VALUABLE INFORAMTION REGARDING ESIM's!
- danieljocobsu72Aspirant
If the same eSIM works on your iPad, it’s likely a device or firmware compatibility/config issue on the M7 side, so checking carrier support for that model and re-provisioning the eSIM usually helps. Clear troubleshooting steps like this are easier to follow when well written, and tools like Corretor de Texto can help keep the details precise and structured.
- PeterPrcekAspirant
Hello there, since i bought this router i have only problem to internet connection, is always disconnect from devices and than write that "unable to connect to wifi" im using apple devices, is there any help how to fix this expensive brick? Before i was working with MR1100 there was no problem for several years, just one night stop making wifi signal, but this new one makes me sad, that new super expensive machine does not help at all.
- RSS7Guide
Hello, I have the exact same problem with my eSIM from Free (french operator).
When I try to add it via the NETGEAR App through the QRcode it fails, asking me to retry or cancel.
The other problem is that this eSIM (failed to be added) seems to keep one of the 7 eSIM "slots" in the router, with no way to delete it.
I tried multiples factory resets but it doesn't reset the eSIM chip
I hope for a NETGEAR firmware update that fixes those issues :)
- HARRYHEREAspirant
Hi Ludovic,
If your M7 isn’t accepting the Free eSIM, try these:
- Make sure the M7 supports the required eSIM profile and bands.
- Double-check the QR code or manual configuration.
- Try resetting the network settings or doing a factory reset.
- Confirm with Free that your M7’s IMEI is registered for eSIM activation.
Sometimes the carrier needs to push the eSIM profile to the device before it will activate.
- kevdyasAspirant
Have you requested a new QR code/eSIM? Some providers have single use QR codes/eSIMs
I've got the MH7150 and I've used it with Lyca and Tello for physical sims and then just the esim marketplace
Not all sims support hotspot plans. Some only work with phones/tablets. Did you check with Free to see what they support with their plans?
