P303
Feb 17, 2018Aspirant
MR1100 password wont work with ipad
Hi. My ipad refuses my password as incorrect even though the MR1100 is working perfectly with my Mac with the same password?
This tells us that the problem is the iPad. The MR1100 does not "work with" the wifi clients. It is the other way round. unless you have set up the MR1100 to block wifi devices.
The first trick in such situations is to tell the wifi client to forget that it even encountered the wifi source, the SSID, and to recreate the connection from scratch.
- P303AspirantMR1100 has now stopped working with my MacBook!. I haven’t changed anything in the Mac,diagnostics state everything is working correctly.
- JasonNNETGEAR Employee Retired
Hi P303,
I wanted to check if your MR1100's firmware is up to date with the current firmware version. If so, then did you do a factory reset after the firmware update?
Please let me know if that fixed the issue. :]
- Jason N
Hi P303,
I just wanted to check in with you and see if your issue has been fixed.
- Jason N
