bucometa
Feb 02, 2022Aspirant
MR1100 SE REINICIA CONSTANTEMENTE
Buenos días. Uso mi MR1100 para vigilancia webcam y lo tengo encendido las 24horas del día. Lo tengo sin batería y conectado a un transformador usb. El problema que veo es que cada cierto tiempo (algunos minutos) el MR1100 se reinicia solo, ya he cambiado el cable y el transformador y me se sigue reseteando sólo... ¿qué me puede suceder?
Gracias por adelantado.
Antonio
In inglese per favore
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you - bucometaAspirantGood morning. I use my MR1100 for webcam surveillance and I have it on 24 hours a day. I have it without battery and connected to a usb transformer. The problem I see is that from time to time (a few minutes) the MR1100 restarts itself, I have already changed the cable and the transformer and it keeps resetting itself... what can happen to me?
Thank you in advance.- FURRYe38Guru - Experienced User
Does the resets or restarts stop if you don't use the USB transformer and web cam surveillance?
- JohnPengNETGEAR Expert
In this case, please see whether use battery can help with the issue. MR1100 is an old model and the control chip used in battery has slow response to sudden power boost and can cause the device to restart when using in no battery mode.
The device has implemented charging protection for 7/24 plug in with battery. The battery power will redeuce to 50% capacity when using in this way after 3 days. If you see the battery can't be fully charged, this is normal.
Thanks
- hajoga4863Aspirant
Hello. I utilize my MR1100 for webcam observation and I have it on 24 hours per day. I have it without battery and associated with a usb transformer. The issue I see is that every once in a while (a couple of moments) the MR1100 restarts itself, I have effectively changed the link and the transformer and it continues resetting itself... what can befall me?
Much thanks to you ahead of time.
Model: MR1100|Nighthawk M1 Mobile Router
