igorjrr's avatar
igorjrr
Apprentice
Jan 10, 2023
MR6400 many many many issues
Are we testing a several hundred dollars device paying for it?
- turns on airplane mode by itself, usually right after first time logging in to admin page.
- wifi broadcast stops. Wifi shows as on in device, but it doesn't broadcast.
- turns off ethernet by itself.
- mobile connection disconnects randomly, shows as connected on LCD but disconnected on admin page.
Basically it has a life of its own.
The firmware version is from more than 6 months ago, and it says it's up to date!
Version NTGX65_10.01.41.02
Absolutely horrible.
  • Are we testing a several hundred dollars device paying for it?
    • night64's avatar
      night64
      Hello
      if you have so many issues you can reset it
      With the Router powered on, press and hold the WPS/RESET button (more than 10 seconds) until the SYS LED becomes quick-flash from slow-flash. Then release the button and wait the Router to reboot to its factory default settings.
      may be come down your issues.
      • igorjrr's avatar
        igorjrr
        Apprentice
        Thanks, but it's new. It seems very clearly to be bad firmware (I see other reports of MR6400 being very unstable).
        We are paying to be testers of this product.
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      For Dish MR6400, we are going to release a new FW update later this month. We are waiting for Dish's technical approval.
      Thanks
      John
      • igorjrr's avatar
        igorjrr
        Apprentice
        Thank you, could you please share what are the changes in this firmware? or, at least, if it covers the issues I listed?
  • michaelkenward's avatar
    michaelkenward
    The MR6400 is not one of the WiFi 6 routers covered here.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
