sripley12's avatar
Dec 06, 2023
NBK752 (AX4200) not failing over to 5G
Hi folks
Got the above set up as broadband (Ethernet) set as the primary with mobile 5G as the backup in the event of primary internet failing.
The problem is it’s not failing over. When you log into the dashboard LTE so as active, connection status is connected with a WAN IP address allocated but there is no onward internet connectivity to any devices on the network. If I do a speed test within the dashboard it’s says it’s not connected to the internet.
Power cycle the router and everything springs into life. I’d hoped failover wouldn’t require manual intervention as I travel a lot of my primary broadband is often flakey.
Hoping it’s a config I’ve got wrong - any ideas welcome.
thanks in advance.
Simon
  • Hey thanks - yep all the failover settings are correct.
    I mean if you power cycle router whilst its in the state of thinking its connected to the mobile network but obviously isn't it connect to the mobile network and works...
      • sripley12's avatar
        sripley12
        Tutor
        Ah - interesting.. Oddly I am sure it worked on the day I set up a month or so ago - but the internet failed yesterday and nothing... I've logged a ticket - I'll keep you posted on what I get back.
