Tmaciasm
Apr 22, 2023Initiate
Netgear m6 Pro MR6500 hot spot OVER HEATING
Why is my unit overheating with battery installed while using or charging it. This is my 3rd unit to do the exact overheating. I want to know the fix to this problem.
- JohnPengNETGEAR Expert
Tmaciasm wrote:
Why is my unit overheating with battery installed while using or charging it. This is my 3rd unit to do the exact overheating. I want to know the fix to this problem.1. Please capture model.json file and send PM to me
2. Please detail your network setup.
- How many WiFi clients
- Is Ethernet port enabled and speed
- What is connected to Ethernet port
Thanks
John
- Ak93Aspirant
Hi I have heating issue with my M6 Pro MR6450 from day one even after the last update the issue still not solved.
Because of heating the battery drain so fast. the heating issue presents with both options battery and plug in cable.
- Lori90TutorIt's a common issue with Netgear period. I'm going on my 4th unit. Constantly in heat mode with mine
- ITSS12Aspirant
To keep the MR6500 Cool!!
Works with Netgear Nighthawk M6 Pro, Nighthawk M6, Nighthawk M5, and the Nighthawk M1
Works Great!!
