I_Must_Know's avatar
I_Must_Know
Netgear Mobile App blocked notifications
Hello everyone.
I've been unable to find a solution to this issue.
It's weird enough that Android has this app under System apps.
But the OS will not allow notifications from the Mobile App "All notifications from this app are blocked".
When I go to App notification and switch the enable button, the OS disables it again.
The android os is version 13.
Has anyone here found a solution?
Thank you.
  • I tried the trouble ticket route.  Got a standard reply from the Help Support.  But when I gave them the same information I posted here....."crickets" .
    I should have just stayed with the M1 hotspot.  Even with AT&T raising my grandfather old plan rates.
    • FURRYe38's avatar
      What are you needing notifications for?
  • I want battery status(this m6 runs way hotter than the m1), temperature status, firmware status,
    • FURRYe38's avatar
      I usually keep mine plugged in or just do a quick check on the screen. Only takes a second.
  • How is this MR6150 deployed?  Page 12 of the User Manual recommends removing the battery when it is used in a fixed location:
    And, if it is mobile, I would think it should be within reach.
