Marcus1981
Feb 28, 2021Tutor
Netgear Nighthawk firmware update
I took a netgear nighthawk m1 firmware update on Thursday Night and now it does not show my data usage like it should: https://prnt.sc/109mh9r so Please fix it! I have restarted the modem took the sim out and back in and it hasnt fixed it!
- dcavinsTutor
I'm having same issue. Device showing Firmware version NTG9X50C_12.06.21.00 with a build date of 01/08/2021. I've been unable to find any information concerning this firmware version.
Yeah when I go to the modem page at the bottom it gives me a option to apple or discard and when I hit apply it says retry! so I cant see data usage on the modem or the modem page! I hope they fix this soon or tell us how to fix it!
- ThinchyInitiate
I have the same issue. No data showing after latest update. This is a loss of one of the good features of this router.
- dcavinsTutor
Curious to know what firmware version you are showing on the device now and what ISP you are using.
Firmware: NTG9X50C_12.06.21.00 and Im using At&T
Yeah Im thinking about doing a factory reset, so it will work again! If they dont fix it in a few days!
Well I did a factory reset and it didnt remove the latest firmware update!
