Sebastiii
Oct 26, 2019Star
Netgear Nighthawk m1 MR1100 Firmware 12.06.08 available
Hello,
A new firmware update available in web interface 12.06.08.
Quick test looks goods, maybe it will fix reboot issues.
No changlog available so far it seems
- mliTutor
No problems on USB power and battery out? :smileyhappy:
I did a quick test with original power supply and no more reboot :) (without battery)
UST Tether continue to works.
I did have a wifi issue for 5G sometimes, i did a factory reset just to be sure it's not related to firmware update partially updated.
I'm experiencing some issues with native IPv4 and IPv6 dual stack.
Only either IPv4 works or only IPv6 works.
When only IPv4 works I can't even see any IPv6 address under Settings -> Status -> Network.
When only IPv6 works I can see an IPv4 address.
I've not gotten both working at all with this update and I've reset the device multiple times as well as restarted it and using settings backups.
My phone using the same LTE carrier has no issues doing both IPv4 and IPv6 at the same time.
To solve the IPv4/IPv6 issue I just waited a while and then did another reset. Everything solved and IPv4 and IPv6 works flawlessly again.
- Hi,
This is the changelog :
https://kb.netgear.com/000061374/MR1100-Firmware-Version-12-06-08-00
Also, I have done another firmware update and in final, it was the same version number.
And this time, it gives me back ethernet standby option. :)
- thom127Aspirant
- thom127AspirantMy fault, was because of a proxy in between. All working :)
- ViewpointAspirantHi, since downloading this firmware, I’ve had continuous internet dropping every few minutes. It only comes back on after rebooting. Weird thing though, it will stay on all day so f you’re streaming something. As soon as there’s not constant flow of data, 3 -5 minutes it’s out and have to reboot. Anyone here have any tips?
