Manitou's avatar
Manitou
Tutor
Feb 13, 2026
no software update available
I received a message from Netgear that I should update my MR6450 - Nighthawk M6 Pro mobile router as soon as possible. However, there is no software update available when I request an update through the device's menu. The current software version in my M6Pro is: NTGX65_12.01.54.00 and is from 12 April 2024.
  • Thank you all for your responses and input. The update was rolled out today for my M6Pro. Patience is a virtue.
  • I have made some progress with FDT.exe and did manage install a new firmware,  a secc.cwe, but I need a full / Recovery version as I think there is OS corruption
  • I use the same model MR6450-100EUS
    Latest Firmware: NTGX65_12.01.74.00 (automatic update from the menu)
    • NairB's avatar
      NairB
      Star
      Hi dbjackson20
      I use the same as Manitou
      Same model MR6450-100EUS
  • My latest installed firmware :  NTGX65_12.01.74.00 and RPI 03.00
    • dbjackson20's avatar
      dbjackson20
      Was this for MR6450-EUS100.  I have to update firmware via fdt because my router is not booting.  I want to ensure I seach for the latest firmware.  1 have found 12.01.53 generic eus100
    • rcpax's avatar
      rcpax
      Luminary
      Kindly let us know what the current firmware and PRI versions are after the update. Thank you.
      • NairB's avatar
        NairB
        Star
        Hi rcpax - After update I now have firmware NTGX65_12.01.74.00 and PRI version 03.00
  • No one can help please?
    Netgear support is not possible because ends waranty M6Pro.
    • NairB's avatar
      NairB
      Star
      Hi Manitou - I was having same issue receiving Netgear email but nothing when trying to update via my M6 pro browser admin page until a couple of days ago. I was prompted within my admin page an update is available and now I have firmware version NTGX65_12.01.74.00.
      Hope this helps
    • StephenB's avatar
      Manitou wrote:
      Thnx for the feedback ! I am sure that the message is from Netgear.
      https://view.e.netgear.com/?vawpToken=JSKBJI2VN6YUXL2ZKD3HE6PJ2E.10192
      I buy the M6Pro direct from the Netgear store in 2023-01 , so it is not a device
      distributed by a carrier!
      KevinLiT​ - Can someone from Netgear follow up?
  • StephenB's avatar
    Are you sure this email came from Netgear?
    Firmware for mobile routers is distributed by your carrier (not by Netgear), so you should reach out to them.
