lpfleghardt
Jan 02, 2018Follower
Replacement Battery for Nighthawk M1 (MR1100)
Where can a Nighthawk M1 (MR1100) be purchased? I believe the mobile hotspot device takes a W-10 battery?
Thanks in advance
Model: MR1100|Nighthawk LTE Mobile Hotspot Router
- UK-basedLuminary
Are you asking where to buy the MR1100 and also the battery, or just the battery? If you want to buy the MR1100 itself, from what I've read about it so far is that you need to buy it as part of a mobile internet package from one of the mobile network suppliers in the country where you'll be using it. The reason I've come to this conclusion is that the firmware upgrades for the MR1100 are not available on the Netgear website - they are automatically downloaded by the MR1100 via the specific mobile network supplier. My guess is that the firmware for the MR1100s provided by each supplier may be customised by Netgear for them.
Of course, I could be completely wrong but it may be wise to check this first before buying an MR1100 from another country.
- pkdstuffTutor
Nowhere on this forum or on additional Netgear and AT&T websites can I find information on how to get a replacement battery. So, does anyone know how a battery for the MR1100 might be aquired?
- JasonNNETGEAR Employee Retired
Hi Ipfleghardt,
What provider do you have for your MR1100?
Hi pkdstuff,
If your MR1100 is AT&T then you can purchase a battery through AT&T. It will take around 3 months because I believe they are backlogged on the item. You can contact AT&T to confirm this.
- Jason N
- PgirlAspirantHave had problem with battery for nighthawk m1100. We have two devices. One works great! The other has had problems since the get go and turns out it is because if a defective battery. Att says they do not have any, that I would have to buy a whole new nighthawk unit with everything and have a 2year contract. If don’t want to do that to contact netgear to purchase battery. Netgear says to buy one on amazon or another 3rd party source because they do not sell to individuals. Cannot find one anywhere. Any suggestions?
Hi lpfleghardt & pgirl,
Pgirl is correct. We do not sell the battery individually and that a whole unit would need to be purchased.
Thank you for explaining that for us. :]
- Jason N
- JSchnee21Virtuoso
Hello Pgirl,
How old is your MR1100? If the battery is defective should't they (either Netgear or AT&T) replace the entire hotspot then under the original MFG warranty?
That said, I have no idea how long the hardware warranty is on the MR1100 -- 90 days? 365 days? The whole produce line is less than a year old, it only came out on Telstra last Spring.
Are you sure the battery is defective and not the charger? The oem charger in the box (aka wall wart) seems to be pretty subpar. Most of us have replaced them with a quality QC2 or QC3 rapid charger.
Which carrier do you have Telstra or AT&T? Make sure you have the latest firmware as (if Telstra) as some of the early firmware versions had battery charging related issues.
-Jonathan
- DragonheartFLAspirant
If you look on ebay they offer M-10 replacement batteries for $19.00 but you'll need to be prepared to wait a lil bit because they ship from china.
