Electrical's avatar
Aug 07, 2019
100Mbps throughput on 1Gbps fiber connection
I'm running a throughput test with iperf between an M6100 with 2 physical fiber connections in a LAG configuration that run to a M4100 in a nearby building. I've checked the settings on both devices and see that everything is communicating at 1Gbps but I'm only getting 100Mbps. I have a laptop connected directly to 2/0/44 on the M6100 (vlan 1) from another laptop connected on 1/0/22 on the M4100 (vlan 1.) The M4100 is running 10.0.2.30 firmware and M6100 is on 11.0.0.31.
Previously, I was able to get 1Gbps with this configuration and haven't modified any of the speed settings though the firmware has been updated a couple of times since the original test. Unfortunately, the switches are in production so I'd like to limit the amount of rebooting if possible.
  • Alright, so there's something wrong with the 1Gbps NIC in one of the laptops. We hooked up a new USB-C NIC and are getting the advertised speeds. Thanks for the replies.
  • schumaku's avatar
    schumaku
    Would be interesting to see the SFP+ ports and related LAG config fragments.
    Consider to get in touch with the Netgear support anyway...
    • Electrical's avatar
      Electrical
      Tutor
      M6100 Config
      LLDP Remote Device Summary
      Local
      Interface  RemID   Chassis ID            Port ID             System Name
      1/0/25     155     CC:40:D0:37:80:A8     0/24
      2/0/25     154     CC:40:D0:37:80:A8     0/23
      interface lag 25
      cos-queue min-bandwidth 0 2 0 0 0 0 0
      description 'Building 25'
      vlan participation include 501-505,1030
      vlan tagging 1,501-505,1030
      Media        STP     Physical    Physical    Link      Loop     Partner Flow
      Intf    Type         Mode    Mode        Status      Status    Status   Control
      1/0/25   1000LX       DIS     Auto        1000 Full   Up                 On
      2/0/25   1000LX       DIS     Auto        1000 Full   Up                 On
      lag 25                FWD                             Up                 NA
      M4100 Config
      Local
      0/23       1       A0:63:91:82:26:98     2/0/25              NetGear M6100
      0/24       2       A0:63:91:82:26:98     1/0/25              NetGear M6100
      interface lag 1
      description 'Uplink to CORE'
      ip dhcp snooping trust
      ip dhcp snooping log-invalid
      vlan participation include 501-502,504-505,1030
      vlan tagging 1,501-502,504-505,1030
      exit
      0/7        1000TX       FWD     Auto        1000 Full   Up                 On
      0/8        1000TX       FWD     Auto        1000 Full   Up                 On
      0/9        1000TX       FWD     Auto        1000 Full   Up                 On
      0/10       1000TX       FWD     Auto        1000 Full   Up                 On
      0/23       1000BASE-LX  DIS     Auto        1000 Full   Up                 Off
      0/24       1000BASE-LX  DIS     Auto        1000 Full   Up                 Off
      lag 1                   FWD                             Up                 Off
        Electrical
        Tutor
        I removed cos-queue min-bandwidth from the global config. Will test again and report back.
ProSupport for Business
