fansigain's avatar
fansigain
Follower
Jan 31, 2023
2.5gbe switch MS108EUP broke after 4 days
I bought a Netgear 2.5gbe switch MS108EUP and it completely died after 4 days of use, that's very shocking from a product that claims lifetime warranty. My wife was home and heard a crack noise and all the connectivity was lost after. I've now tested amd the psu is completely dead actually is even shorting any plug that I've tried plugging it. The switch was not using any poe device and only had 3 ports active. This is completely unacceptable from a £300 switch with only 4 days in use and no load on it.
  • schumaku's avatar
    schumaku
    https://my.netgear.com/ -> [View Product] -> [Request hardware support] -> Describe your issue -> Add additional information (Attachments) -> [Send] ... NETGEAR Support will contact you via email after reviewing the request.
    Hardware can break any time ... the fist second ... or cease operational state in days or weeks. Nothing what happens every day, however.
ProSupport for Business
