FabrizioMM's avatar
FabrizioMM
Follower
May 29, 2019
20gb dual ring Ethernet network
I need to create a double-ring fiber optic network. I would like the connection to be 20Gb and the ring has at least 8 switches. Which Ethernet switch do you recommend? Do you think it is appropriate to change network topology? I need to manage at least one fault. thanks a lot
1 Reply
ProSupport for Business
