Greg_Hejl
Mar 23, 2007Aspirant
7328s VLAN trunking
Greetings, I want to create a tagged link to my router's subinterfaces. Do I use link aggregation for this? does LAG automatically carry all switch traffic? or does the port(s) need to be include...
cliftonyuen
Aug 09, 2007Aspirant
we too also having the same issue. I've setup LAG port 1 which include 1/1 and 1/2 and they are connected to a Foundry L3 switches using LACP. That seems to be OK. But I'm also having issue setting up the LAG port as 802.1q tag port so that vlan traffic from two different vlans can be "routed" thru. Anyone have any idea how the vlan tagging works? greatly appreciate your suggestion...
best regards,
clifton
best regards,
clifton
- Feb 22, 2022Retired_Member
