Greg_Hejl
Mar 23, 2007Aspirant
7328s VLAN trunking
Greetings, I want to create a tagged link to my router's subinterfaces. Do I use link aggregation for this? does LAG automatically carry all switch traffic? or does the port(s) need to be include...
LapGear1
Sep 26, 2007Aspirant
To create a 802.1q trunk port, you need to manually include the trunk port as a "tagged" member of all the VLANs you want to trunk to the other switch.
If your trunk port is a LAG, after you created the LAG, make the LAG interface a "tagged" member of all the VLANs you want to trunk to the other switch.
- Feb 22, 2022Retired_Member
