Greg_Hejl
Mar 23, 2007Aspirant
7328s VLAN trunking
Greetings, I want to create a tagged link to my router's subinterfaces. Do I use link aggregation for this? does LAG automatically carry all switch traffic? or does the port(s) need to be include...
LOBO_TELSA
Nov 26, 2008Aspirant
This is my configurati0n, I think I´m doing what Lap say´s but, it doesn´t work, can some body helpme ? (NOTE: I made same configuration in booth switches, same ports, same vlan id etc.)
Switch #vlan database
Switch (vlan)#vlan 2
Switch (vlan)#vlan 3
Switch (vlan)#exit
Switch #configure
Switch (configure)#interface range 1/0/10-1/0/20
Switch (configure interface range 1/0/10-1/0/20) #vlan participation include 2
Switch (configure interface range 1/0/10-1/0/20) #vlan participation exclude 1
[COLOR=#1f497d][FONT='Calibri','sans-serif']Switch (configure interface range 1/0/10-1/0/20) #vlan pvid 2
[COLOR=#1f497d][FONT='Calibri','sans-serif']Switch (configure interface range 1/0/10-1/0/20) #vlan tagging 2
[/FONT][/COLOR][/FONT][/COLOR]
Switch (configure interface range 1/0/10-1/0/20) #exit
Switch (configure)#interface range 1/0/21-1/0/30
Switch (configure interface range 1/0/21-1/0/30) #vlan participation include 3
Switch (configure interface range 1/0/21-1/0/30) #vlan participation exclude 1
[COLOR=#1f497d][FONT='Calibri','sans-serif']Switch (configure interface range 1/0/21-1/0/30) #vlan pvid
[/FONT][/COLOR][COLOR=#1f497d][FONT='Calibri','sans-serif']3
[/FONT][/COLOR][COLOR=#1f497d][FONT='Calibri','sans-serif'][COLOR=#1f497d][FONT='Calibri','sans-serif']Switch (configure interface range 1/0/21-1/0/30) #vlan tagging 3
[/FONT][/COLOR][/FONT][/COLOR]Switch (configure interface range 1/0/10-1/0/20) #exit
Switch (configure)#exit
+++++ Here if i plug 2 laptops with same subnet address in the vlan1, the echo works fine, I mean i can ping each laptop if they´re in vlan1, but if i change booth laptops to vlan2 i can´t ping none +++++ What am I doing wrong???
Switch #configure
Switch (configure) #interface 1/0/40
Switch (configure interface 1/0/40) #vlan participation include 2
Switch (configure interface 1/0/40) #vlan participation include 3
Switch (configure interface 1/0/40) #vlan pvid 2
Switch (configure interface 1/0/40) #vlan pvid 3
[COLOR=#1f497d][FONT='Calibri','sans-serif']Switch (configure interface 1/0/40) #vlan tagging 2
[/FONT][/COLOR][COLOR=#1f497d][FONT='Calibri','sans-serif']Switch (configure interface 1/0/40) #vlan tagging 3
[/FONT][/COLOR]Switch (configure interface 1/0/40) #exit
Switch (configure) #exit
Switch # copy running nvram……
+++ Here, when I plug laptop1 in switch1-vlan1 and laptop2 in switch2-vlan1 the ping response is OK, but if i connect laptops in vlan2.... :(:confused:
So please, I need help.
- Feb 22, 2022Retired_Member
