netgipg
Feb 04, 2014Novice
7328sv2 firmware, changes 8 to 10?
Hi,
Looking for the latest downloads for a GSM7328Sv2 I see 8.0.3.34 and also 10.0.0.31.
2 version numbers is quite a jump. I have 8.0.3.25, do I go up in 8 or on to 10?
Thanks
- jmizoguchiVirtuosoI had some other model that need increments. I would read any notes attach to the file or have instruction on the products support page.
- netgipgNoviceI would normally do the last v8, then the v10, but my point really is that there is nothing relevant in the notes or on the support page. If there is please post a link.
- jmizoguchiVirtuosoIf not listed then ask support directly on confirm answer
Usually it will not load if don't like it. Happened on my switch in the past - jmizoguchiVirtuosoDon't take my word but looks like there is no incremental
- netgipgNoviceThere is no documentation for v10 available at all that I can find. Please correct/direct me.
A short script that I used before now gives me an error "An invalid interface range has been used for this function. An interface range must be 1000 characters or less." as soon as I type "interface range "
Looks like I'll be booting back in to v8 tonight. - jmizoguchiVirtuosoIf not listed then ask support directly on confirm answer
- Jedi_ExileNETGEAR Expert
netgipg wrote: There is no documentation for v10 available at all that I can find. Please correct/direct me.
You the v10 CLI guide from following link:
http://www.downloads.netgear.com/files/GDC/M5300/M5300%20CLI%2027Nov2012.pdf
As for the range, modify your script since the new firmware 10.0.0.x follow M5300 CLI changes
instead ofinterface range 1/0/1-1/0/20
Now you can dointerface 1/0/1-1/0/20,1/0/24,1/0/28-1/0/30
I hope that helps.
