gfvalvo's avatar
gfvalvo
Guide
May 13, 2016
802.11q VLAN
My ProSAFE GS116E is configured for Advanced 802.1q VLAN mode. I’m wondering what happens when an Ethernet frame arriving to a port from the outside is tagged for a VLAN Group that the port is not a member of. I can think of three possibilities:
* The frame is dropped (ignored).
* The frame enters the switch with its current VLAN tag.
* The frame enters the switch but its tag is changed to the port’s default PVID.
Anyone know for sure?
Thanks.
Greg
  • Hello gfvalvo,
    Answer number three is the correct one. It will let the frame enter the switch but it its tag will be changed to the port's VID.
    Thanks,
1 Reply
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello gfvalvo,
    Thanks,
ProSupport for Business
