pertronic
Apr 03, 2012Aspirant
Access management VLAN from other VLANs
We will soon replace our switches with managed switches from Netgear (a couple of GS724T and one GSM7224). I've been successfully testing a multiple VLAN config with the GSM7224 handling the inter...
ebelotto
Jul 14, 2012Novice
We are using almost the same in ower company.
When you use VLAN routing, choose one switch to be the core switch layer 3 (router) e the others just layer 2. If you don´t aply any ACL to them, you´ll be able to access the management interface in every switch on the ip address that you configured on the switches. We configured 1 VLAN layer 3 to be the management VLAN e use OSPF for distribue the statics routes. In that VLAN, all the switches have one IP address and we access the interface with this IP. This VLAN isn´t the VLAN 1. It works fine.
