netsmart
Oct 26, 2016Aspirant
Accessing sites thru local network VPN hardware
We have a Prosafe FVS336G Firewall/VPN. We'd like to set this so that users within the LAN can access sites on the internet as if it were an external VPN. A loop back tunnel of sorts to other sites using our own VPN. This would allow anonymous and non-geo based net access. I can add another prosafe router in between our ISP fios box if necessary.
Thanks.
- JohnRoNETGEAR Employee Retired
Hello netsmart,
Welcome to the community!
You can do a box-to-box VPN configuration if you will have two FVS336G's on both ends. However, your fios box, does it have routing capabilities?
Thanks,
- netsmartAspirant
Yes, the Fios Gateway is a router ( Fios G1100). it does routing. The FVS336G is connected to one of it's Lan ports.
The task here is to use the FVS336G as a VPN service such that INCOMING data is encrypted ( trading data for example ) and geolocation is not available to sites ( via IP lookup -- verizon ).
So instead of subscribing to a VPN service we provide our own, in a nutshell.
Thanks.
- FramerVNETGEAR Employee Retired
Hi netsmart,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
