ChristopheVL
May 26, 2016Aspirant
ACL vlan M4100
Dear, We would like to create an access list to isolate our Guest Wifi network from all the other vlan. When i do so, the other SSID's diseapper from our laptops. I have applied the access l...
- Retired_MemberJun 01, 2016
Maybe it's filtering the DHCP packets.
To troubleshoot, try to add a rule to allow DHCP packets.
Example: (this is obviously NOT the exact rule to match only DHCP packets, but just a simple rule for the test)
ip access-list Deny_Guest_Intervlan_Routing
permit udp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 67
permit udp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 68 deny ip 10.253.2.0 0.0.0.255 10.253.0.0 0.0.255.255 permit ip 10.253.2.0 0.0.0.255 0.0.0.0 0.0.0.0 exitIf this ACL works (you can get DHCP address), then you'll have to write the proper ACL, something like (this is just an example):
! DHCPDISCOVER
permit udp 0.0.0.0 0.0.0.0 eq 68 255.255.255.255 0.0.0.0 eq 67
! DHCPOFFER
permit udp <dhcp_server_ip> 0.0.0.0 eq 67 255.255.255.255 0.0.0.0 eq 68
! DHCPINFORM
permit udp 10.253.2.0 0.0.0.255 eq 68 255.255.255.255 0.0.0.0 eq 67
! DHCPACK
permit udp 10.253.2.0 0.0.0.255 eq 67 <dhcp_server_ip> 0.0.0.0 eq 68
permit udp 10.253.2.0 0.0.0.255 eq 67 255.255.255.255 0.0.0.0 eq 68
! Internal traffic deny ip 10.253.2.0 0.0.0.255 10.253.0.0 0.0.255.255
! Internet traffic permit ip 10.253.2.0 0.0.0.255 0.0.0.0 0.0.0.0 exit
DaneA
May 26, 2016NETGEAR Employee Retired
Hi ChristopheVL,
Welcome to the community! :)
Kindly answer the questions below:
a. Was this working fine before?
b. Does the ACL works even though the SSIDs do not appear on the laptops?
Let me share this article as reference guide and check if the SSIDs will be detected by the laptops when ACLs are applied.
DaneA
NETGEAR Community Team
- ChristopheVLMay 27, 2016Aspirant
Hi DaneA,
A. This is a new config!
B. No it doesn't work.
Can you give me an article for this switch, because this is a L2+ with router capibilities
Can you give me an example on how you configure it true cli?
Thanks in advance
