roriol
Jul 16, 2017Aspirant
Adding a new switch into the middle of an existing stack
I have an existing stack of various M5300 switches. The switches are dispersed, configured as a redundant ring connected by multi-mode fiber using AXM761 SPF+ fiber modules. It works great. Th...
DaneA
Jul 20, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to access the article I've shared and used it as your guide in adding a new switch to an existing stack? If yes, is everything working fine?
DaneA
NETGEAR Community Team
roriol
Jul 20, 2017Aspirant
Dana,
The article I had already seen online. Step 4 of the article refers to adding the new switch to the top or bottom of the switch. I have a virtual stack configuered as a redundant ring using 10GB fiber. Each of the switches are in different IDFs in the building. I want to add this new switch between current switch 3 and 4.
I am concern that the new switch will be assigned switch "5" and the switches would be numbered 1-2-3-5-4 (and then back to 1). How import is it that the switch number stay in order?
