rasar117
May 07, 2019Aspirant
Adding a new switch into the middle of an existing stack
Hi All,
I am adding a GSM7328Sv2 to a stack. They have the same version of OS. The steps is as below.
1. Disconnect the redundant stack cable. 2. Disconnect the redundant stack cable that co...
JohnC_V
May 08, 2019NETGEAR Employee Retired
Hi rasar117,
Welcome to our community! :)
As per checking, you are adding the new switch to your previous stack. No pre-configuration needed to be changed by default unless you do have VLANs that are needed to be added on your new switch. If you encounter any issues by adding the new switch to the stack, you could try to reboot all the switches and have them re-elect the master stack.
JohnCarloV
NETGEAR Community Team
rasar117
May 10, 2019Aspirant
Hi John,
Thank you for your information. The stack does contain VLANs. The new switch is not connected to any device. So just to confirm that the VLANs will have to be added beforehand to the new switch. Does not adding it to a stack automatically add the VLN to the new member?
Kind regards
Raihan
