pacificcloud
Aug 17, 2017Guide
Backup via NMS300 stopped working after firmware update on M4300 switches
Hi All, I have multiple M4300 switches, SRX5308 firewalls and WC7600 controllers. I automatically backup configuration of all these devices via NMS300. Recently I updated firmware on all switche...
DaneA
Aug 21, 2017NETGEAR Employee Retired
Hi pacificcloud,
Welcome to the community! :)
What is the version of the NMS300 are you using? I researched about the issue you have experienced and found out that it should be solved by using the latest version of NMS300. I recommend you to download and install the latest version of NMS300 which is v1.6.0.3.
You can download the latest version of the NMS300 on the following links below:
NMS300 Software Release 1.6.0.3 for 32-bit Windows
NMS300 Software Release 1.6.0.3 for 64-bit Windows
Kindly read the release notes of NMS300 v1.6.0.3 here.
DaneA
NETGEAR Community Team
- pacificcloudAug 21, 2017Guide
Hi DaneA,
Thank you for your reply.
I have doubled checked the version of NMS300 and confirm that I run the latest v1.6.0.3.
Max.
- DaneAAug 22, 2017NETGEAR Employee Retired
Thanks for the feedback.
Let us isolate the problem. Were you able to reset the M4300 switches back to factory defaults after upgrading the firmware then reconfigure it from scratch? If yes, kindly revert back the firmware of one of your M4300 switches to the version where it was working fine before. Then, check if you are able to perform automatic backups of the configuration file of that specific M4300 switch again using NMS300 v1.6.0.3.
DaneA
- pacificcloudAug 22, 2017Guide
Hi DaneA,
Appreciate you help.
This is what happend:
1. I have received a bunch of emaisl from Netgear "Important Security Update from NETGEAR:
New Firmware Is Available for Your Product "Our records indicate that you own the following product: XSM4324S. NETGEAR is aware of one or more security vulnerabilities affecting your NETGEAR product. NETGEAR has released firmware fixes for one or more vulnerabilities affecting your XSM4324S.
2. As per Netgear recommendations I updated the firmware via NMS300 on the switched to the latest version
3. After the update all switches work well and I do not see any issues with the new firmware.
4. Scheduled backup of the switches via NMS300 does not work since the upgrade.
5. Back up of all other devices (firewall and wireless controller) still works well via NMS 300.
To answer your question: "Were you able to reset the M4300 switches back to factory defaults after upgrading the firmware then reconfigure it from scratch?"
No, I did not reset switches to factory defaults after upgrading the firmware. Firmware upgrade on all switches was suscessfuly completed from NMS300.
