pacificcloud
Aug 17, 2017Guide
Backup via NMS300 stopped working after firmware update on M4300 switches
Hi All, I have multiple M4300 switches, SRX5308 firewalls and WC7600 controllers. I automatically backup configuration of all these devices via NMS300. Recently I updated firmware on all switche...
DaneA
Aug 21, 2017NETGEAR Employee Retired
Hi pacificcloud,
Welcome to the community! :)
What is the version of the NMS300 are you using? I researched about the issue you have experienced and found out that it should be solved by using the latest version of NMS300. I recommend you to download and install the latest version of NMS300 which is v1.6.0.3.
You can download the latest version of the NMS300 on the following links below:
NMS300 Software Release 1.6.0.3 for 32-bit Windows
NMS300 Software Release 1.6.0.3 for 64-bit Windows
Kindly read the release notes of NMS300 v1.6.0.3 here.
DaneA
NETGEAR Community Team
pacificcloud
Aug 21, 2017Guide
Hi DaneA,
Thank you for your reply.
I have doubled checked the version of NMS300 and confirm that I run the latest v1.6.0.3.
Max.
