swu5966
Jul 06, 2016Aspirant
Basic VLAN/Routing Config GSM7224
Hello All, My background has been more in the HP Procurve world and I am in a Netgear environment and looking for some basic configuration help to get me rolling. I have GSM7224 and GS748T sw...
JohnRo
Jul 06, 2016NETGEAR Employee Retired
Hello swu5966,
Welcome to the community!
You may still have to use your existing firewall to handle the routing since the FSM7224 is not a fully managed switch and will not provide DHCP and routing. See the following example configuration on the following links below:
How do I configure VLAN Routing on a smart switch?
Multiple VLAN Configuration Between NETGEAR Firewalls and Switches
Let me know if this helps.
Thanks,
