hugeyeti
Sep 06, 2022Aspirant
Can a managed switch be used as unmanaged?
I saw a solution for this question by Laurent Masia but I may be missing some relevant info to make the endpoints talk to the 'main' switch. The latest firmware was downloaded on XS708T and no fu...
schumaku
Sep 12, 2022Guru - Experienced User
The default config of these switches is all in a single VLAN (technically #1), however the orts are configured to be associated with VLAN 1, PVID 1 - so the basic L2 behavior is very similar to an unmanaged switch.
Figure out on how the CRS312-4C+8XG-RM ports are configured.
hugeyeti
Sep 12, 2022Aspirant
Turns out the Netgear managed switch XS708T was not able to retrieve an IP address from Mikrotik after several factory resets and attempts at configuration with support.
RMA has been issued and a new managed switch will be tested: XS712Tv2.
