JonCJohnson's avatar
JonCJohnson
Follower
Jul 21, 2017
Can I turn off EEE on a M4100?
Hello- Does anybody know if EEE (Energy Effecient Ethernet) can be disabled on the M4100?
Thanks
1 Reply
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi JonCJohnson
    Yes, you can disable EEE on M4100 Gigabit models.
    You can refer to the Web GUI user manual page 51:  Select System  Management  Green Ethernet > Green Ethernet Configuration
    • Select the Auto Power Down Mode Disable or Enable radio button
    • Select the EE Mode Disable or Enable radio butto
    Don't forget to Apply your settings (to update the running-config file), and then go Maintenance  Save Config in order to write the startup-config file (persistent after a reboot).
ProSupport for Business
