tsep
Jan 21, 2019Follower
Cannot upload TLS cert, Error: "SSL PEM Server Certificate file upgrade through HTTP is failed"
We are trying to upload a custom TLS certificate using the Webinterface
Maintenance - Upgrade - HTTP File Upgrade - SSL Server Certificate PEM File
but the Upload fails with the following error message
There wasn't any problem uploading the Trusted Root Certificate File and the DH Strong Encryption Parameter File
Maintenance - Upgrade - HTTP File Upgrade - SSL Trusted Root Certificate PEM File
Maintenance - Upgrade - HTTP File Upgrade - SSL DH Strong Encryption Parameter PEM File
The same error message is displayed, if we are trying to download the certificate from a TFTP Server
Security - Access - HTTPS - Certificate Download - SSL Server Certificate PEM File
We have already followed the steps detailed in the previous discussion
M4300-28G (GSM4328S) HTTPS Admin "ERR_SSL_PROTOCOL_ERROR"
So the SSL Server Certificate PEM File contains the private key, followed by the server certificate, followed by the intermediate ca certificate.
We generated a SSL Server Certificate PEM File by using the Webinterface
Security - Access - HTTPS - Certificate Management - Generate Certificates
and tried to upload the previously served certificate, but it fails with the same error message.
the device runs firmware version 12.0.7.10
Has anyone experienced such an issue before?
Is there any information regarding the required format of the pem file?
Any help would be appreciated.
- DaneANETGEAR Employee Retired
Hi @tsep,
Welcome to the community!
I inquired your concern to the higher tier of NETGEAR Support. As per the feedback of the higher tier of NETGEAR Support, it was suggested that you open a chat or online support ticket with NETGEAR Support for further investigation. Kindly state your concern and enumerate the steps you did as well as upload a screenshot of the error message you encountered.
DaneA
NETGEAR Community Team
The "Open a support ticket" response just makes noise in the forum. CWOT (colossal waste of time).
