dlupfer
Mar 08, 2018Aspirant
Can't add additional VLANs to JGS524Ev2
 Good afternoon,     I am trying to setup some VLANs on my switch, but am having a little issue. I am in Advanced 801.2Q, and upon enabling it gives the warning that it will clear existing VLANs, I sa...
- Mar 08, 2018
Hi Dan,
First add the port to the VLAN 10 ie. as [U]ntagged. Now you should be able o change the PVID from 1 to 10, and then remove the port from the VLAN 1.
Yes, I understand why users are struggling over this - as there can be a kind of an (potentially invalid) config in place for a moment. It hit's me every other attempt while mobing a port from a VLAN ID to another VLAN ID.
-Kurt
schumaku
Mar 08, 2018Guru - Experienced User
Hi Dan,
-Kurt
