melvin1817
Feb 07, 2024Aspirant
Can't enable Link Aggregation on Netgear "GS724TS" Switch
I'm trying to enable link aggregation on my Netgear GS724TS Smart Gigabit Ethernet Switch and it is not working. The Link Aggregation Groups show notPresent under Status. See image bellow: ...
schumaku
Feb 07, 2024Guru - Experienced User
Before you can enable the LAG Configuration, key is to define the LAG Memebership first.
Cumbersome, these old ane EoL switch Web UI were designed and implemented for older browsers and were workable on IE - modern browsers like Chrome and Edge, and you might to have to run some peek-and-poke with alternate Web browsers. Good experience in general can be achieved using Firefox.
Historically, those switches are dating back from the year 2009, and used to be administered primarely by using the legacy Smartwizard Utility - long before Web-based management became more common.
Either way, these are in no aspect Managed Switches, much more legacy variants of Smart Switches, so I'm requesting a moderator to move this thread to the Plus And Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management.
