melvin1817
Feb 07, 2024Aspirant
Can't enable Link Aggregation on Netgear "GS724TS" Switch
I'm trying to enable link aggregation on my Netgear GS724TS Smart Gigabit Ethernet Switch and it is not working. The Link Aggregation Groups show notPresent under Status. See image bellow: ...
BrianL
Feb 07, 2024NETGEAR Moderator
Hi melvin1817,
Is the unit running on its latest Firmware 5.2.0.11? Also, can you share a screenshot of the LAG Membership page to see if admin mode is enabled? The error message is unusual though.
Kind regards,
melvin1817
Feb 08, 2024Aspirant
I'm running on firmware v5.2.0.11
Here are some screenshots of the LAG Membership page:
This is a screenshot of the Ling Aggregation configuration of my Synology DiskStation NAS
- schumakuFeb 08, 2024Guru - Experienced User
Head again to LAG - Membership - Advanced ... there is supposed be a way to define the adapters (ports) for the LAG. Currently, there is indeed no port participating in the LAG. Here how it looks on a much newer switch (last gen with the old UI design):
