aesterling's avatar
aesterling
Can't load switch web interface, it doesn't return pings, but still passes network traffic
Hello, any help with this problem is appreciated:   I'm unable to load the web interface of our switch (from multiple computers, browsers, etc), it doesn't return pings, but it continues to pass n...
  • DanielZhang's avatar
    DanielZhang
    Mar 05, 2017
    Hi Aesterling,
    Because the IP address of ezConfig is same as default network/management VLAN IP address on M5300.
    So the old IP address will lost when input a new one just like configre new IP address on same port.
    There is a configuration alter about management IP address of ezConfig like below:
    (SW1) #ezconfig
    EZ Configuration Utility
    Hello and Welcome!
    This utility will walk you thru assigning the IP address for the switch management CPU. It will allow you to save the changes at the end. After the session, simply use the newly assigned IP address to access the Web GUI using any public domain Web browser.
    Assigning an IPv4 address to your switch management
    Current IPv4 Address Configuration
    Management VLAN ID: 1
    IPv4 Address Assignment Mode: Manual
    IPv4 Address: 192.108.130.2
    Subnet Mask: 255.255.255.0
    Default Router IPv4: 192.108.130.1
    Routing Mode: Enable
    IPv4 address has been assigned manually. What do you want to do?
    C - Change IPv4 address.
    D - Assign IPv4 address for the switch using DHCP Mode(current IPv4 address will be
    lost).
    N - Skip this option and go to the next question.
    Q - Quit.
    ? - Help.
    (C/D/N/Q/?)? C
ProSupport for Business
