storminnorman
Aug 25, 2016Aspirant
Can't Ping PC on switch
I have a GS110TP wiht two Windows 7 comptuers attached. I can ping oen but not the other. I checked the ports configurations and they are the same The one I cn ping is on port 7 and the 1 I can...
JohnRo
Aug 26, 2016NETGEAR Employee Retired
Hello storminnorman,
Welcome to the community!
Did you check if the other win7 computer is getting an IP address? If so, check if that computer can ping your gateway or DHCP server.
Thanks,
storminnorman
Aug 26, 2016Aspirant
Yes the PC gets an IP and can access the network. I am goign to try swithcing the ports on the switch wiht the other PC that I can ping and see if that makes a difference
And the firewall is off...
- storminnormanAug 26, 2016Aspirant
Update on this case.
The issue is with both PC's and it seems that the DNS is not being updated on our servers possibly the "switch" needs to be added as a DHCP relay.
DHCP shows the correct address but the DNS server shows a different address. DHCP is coorect
- JohnRoSep 08, 2016NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
