swealpha
Mar 11, 2019Aspirant
Cheapest switch that can limit bandwith speed by interface?
Hello! Do you guys know what the cheapest switch is that can limit bandwith speed by interface? Thank you!
- Mar 13, 2019
Yes, between multiple VPN providers.
Looks like its kinda hard to complete if we dont buy a pfSense router that is little to advanced for me.
Thank you.
swealpha
Mar 12, 2019Aspirant
Sorry for not being more clear.
I mean if its possible to rate limit upload and download. I see some switches only limit the upload speed.
Thank you!!
schumaku
Mar 12, 2019Guru - Experienced User
Limiting egress is one thing rather easy, but having massive consequences. But how would you implement an ingress bandwidth limitation - which would be at the end of the day just ignore and drop packets or what? Of course, there are technologies like pause frames, flow control, and back pressure.
Then think again why the IEEE has abandoned any plans on a standardisation of a granular flow limitation IEEE P802.3ar Congestion Management Task Force some decade(s) ago.
An Ethernet infrastructure does poorly compare with a hydraulic system.
What exactly - and why - do you want to achieve?
- swealphaMar 12, 2019Aspirant
Two houses are sharing same internet connections.
So i would like to split 100Mbit. to. 2x50Mbit.
I found this router that can limit both upload and download, dont know if it works any good.
Netgear GS108Ev3
http://www.downloads.netgear.com/files/GDC/GS105EV2/WebManagedSwitches_UM_EN.pdfWhat do you think?
Thank you- schumakuMar 12, 2019Guru - Experienced User
That's a switch, not a router.
I would suggest using a proper router (no consumer ***** - that's not against the Netgear Smart Managed Plus or Pro switches) allowing to apply some rules for bandwidth management and reservations, and allow to give more bandwidth if not in use otherwise.
Sorry i mean switch ofcourse as topic.
Do you guys know any switches that is made for business use? That can limit bandwith per interface?
I dont think netgear have any routers that support hardware acceleration on OpenVPN. Or else it would be a supergreat idea to have a netgear router!
Thank you.
