Hisham_Nagia
Aug 26, 2017Follower
Compatibility Information Needed
Hello , I have big project ( complete industrial complex ) includes building a number of physically separated LANs to host data ( PC / Servers / Printers ) , IP Camera Surveillance , Industrial Machi...
Hopchen
Aug 26, 2017Prodigy
Hi,
In the future, you can simply have a look in the datasheets to see if something is compatible.
The datasheet for the M4300-12X12F
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
The switch is compatible with both fibre modules you mention.
The datasheet for the S3300-28X-PoE+
http://www.downloads.netgear.com/files/GDC/datasheet/en/S3300_GS728TX_GS728TXP_GS752TX_GS752TXP.pdf
The datasheet for the GS728TP
https://www.downloads.netgear.com/files/GDC/datasheet/en/GS516TP-GS728TP-GS728TPP-GS752TP.pdf
The switch is compatible with the AGM732F.
Cheers
