kiheiman
Dec 07, 2016Aspirant
Configure IP Directed Broadcast
We have a GSM7324 router and recently turned on the routing function. We now have two VLANs and different subnets. We need to get WOL packets on one VLAN to PCs on the second VLAN. The routing fun...
Retired_Member
Dec 07, 2016Hi kiheiman,
Welcome to our community!
I think you should enable routing global if you want the Switch to forwarding L3 packet between different subnet.
GUI web go to 'Routing-->IP-->IP Configuration' and set the 'Routing Mode' to 'Enable', then click the 'Apply' button.
Please try again and check is it ok?
BTW: What do you mean WOL packets? We need more detailed information about this packet.
Hope that it helps !
Eric_z
NETGEAR Employee
kiheiman
Dec 08, 2016Aspirant
The WOL is the Wake on LAN packets. We have L3 routing enabled. The WOL packets are L2. I have seen a number of of Internet posts about WOL packets not being able to go between VLANs unless the "IP Directed Broadcast" option is enabled. I am looking for specific instructions on how that option can be enabled on a GSM7324 L3 switch, other than just changing the option from Disable to Enable. I am assuming that other options on the IP configure page need to be changed, along with enabling the Directed Broadcast option. Hope that helps.
