autoitaus's avatar
Jan 07, 2019
Connect M5300 & S3300 via SPF
I have a direct attached SPF cable (AXC761) and have plugged it in from a M5300 to a S3300 switch. Both ends are showing as link down and there is nothing plugged in to the corrosponding ethernet (CAT6) ports.
Have I missed a step?
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi autoitaus,
    It seems that you are having issues connecting a DAC to your switches. May you be able to check if both of the ports are set as "Stack" and not as "Ethernet"? Go to System > Stacking > Advanced > Stack-port Configuration.
    Please let me know if this will work.
    • autoitaus's avatar
      autoitaus
      Tutor
      Hi John,
      I'm not trying to create a stack, just a normal uplink.
      The SPF ports in question (Port 46 on the M5300) cannot be configured for a stack anyway. The only ports that support a stack on the M5300 are 49,50,51,52
      • JohnC_V's avatar
        JohnC_V
        autoitaus,
        My apologies for the confusion.
        May I know the exact model number of your M5300? Have you checked the S3300 if the port is set to "Ethernet"? It seems that this device has a lifetime chat support, I suggest you to open a ticket on NETGEAR support and please let them know the status of your switch so that your issue will be addressed immediately.
ProSupport for Business
