L0g1t3ch
Sep 07, 2016Aspirant
connecting 2 FS728TP via sfp port
Hi, im trying to connect two FS728TP switches (located in different offices that are q50 feet apart) via the SFP connecters. They are strung together with multimode fibre cable but I cant seem to get...
- Sep 09, 2016
Fixed it!
Aparently my hunch was right and the fault was with the fiber cable. The engineer had plugged the sedning fiber core on the back of the patch panel into the same port on the opposite end instead of the receiving connector. As soon as he flipped it over the sfp module came to life and voip traffic started flowing.
Happy days :)
JohnRo
Sep 08, 2016NETGEAR Employee Retired
Hello L0g1t3ch,
Welcome to the community!
What SFP modules are you using on both ends? Has this been working previously?
Thanks,
- L0g1t3chSep 09, 2016Aspirant
Hi JohnRo,
Thanks for getting back to me. Heres what I'm trying to do. My firm is expanding its office and taken on some new vacant floor space on the other side of the building. So I need to connect this office (call it Office-A) to the new office (call it Office-B). The connection will have to carry voip, data and internet traffic on two seperate networks, linked together with OM4 Multimode, 8 core, fiber cable, terminated in each offices server room at a patch panel. This then has four connectors which will go to a variety of switches via sfp modules.
For the moment Im focussing on the voip network which in Office-A is made up of 3 Netgear FS728TP switches stacked together via ethernet cable to Office-B which will have one brand new FS728TP. The SFP modules in the Netgears are all AGM731F sx\lc connectors with 2m OM4 MM sc\lc fiber cables running to the patch panels. The problem is I cant get one side to see the other and from my understanding you shouldnt have to configure anything on the Netgears apart from an ip address (all in the same 192.168.83.0 subnet) for it to work. After a lot of fault finding I pulle done of the switches from Office-A and installed it into Office-B, linked it to the new switch via ethernet and checked they coudl see each other, (which they could). Then connected the fiber cable, ran the management app and was still unable to detect the other side. I also connected one of teh voip phones (known to work) to the new switch and still no joy.
Checks carried out include:
Making sure the fiber port at either end wasnt sharing the ethernet port for the existing stack
Swapped sfp modules around (dont have any spares and tried some from Cisco anyway)
Tried different 2m fiber cables
Tried the sfp ports on 2 cisco 10 port switches
Rebooted everything
Tried different patch points
All without success. The only difference I can see is that the firmware version are different (Office-A switches have been in there for at least 3 years) but I dont think that would make any difference. Running a cable check from the Switches Web gui reveals port g25 (which has the fiber cable attached) is down but there is an unknown cable type installed. So unless I'm missing something in the config (and I've looked extensively) my best guess is that theres something wrong with the fiber cable in the ceiling or the patch panels. I do have the engineer coming back in today to check it but is there some obscure setting I am missing?
many thanks
Fixed it!
Happy days :)
- JohnRoSep 09, 2016NETGEAR Employee Retired
Hi L0g1t3ch,
Glad to know it is working! The SFP ports are mostly plug-and-play so hardware is the first one to look at, we'll have to make sure that the modules and the fibre cables are working okay.
Wishing success to your expansion.
Thanks,
