scott-ori
May 14, 2018Aspirant
Connecting M4300 to GS752
I just added a M4300 12x12f switch to add 10gb networking for my Hadoop cluster. The rest of our network is GS752 switches with 4x spf+ connectors on each on. I thought that those ports could be co...
Retired_Member
May 14, 2018Hi scott-ori,
Welcome to the community!
Could you please confrim what the detailed switch type of your GS752?
If it's GS752TP, only support 48 1G copper port and 4 1G fiber SFP port, not support SFP+ 10G port.
If it's GS752TXS, it support 48 1G copper port and 4 10G fiber SFP+ port.
Hope it helps!
EricZ
NETGEAR employee
scott-ori
May 15, 2018Aspirant
It is actually a GS752TP switch. So I was mistaken in what connectivity it has, and I will not be able to use the SFP+ connection on it, just standard cat6 cable to connect the two. Is that correct?
